https://vimeo.com/60993010 (part1/day)
Canon EOS C100 + EF-S 18-135mm/f3.5-f5.6 (Peripheral Illumination Correction on / EF-S Correction off)
and XF100 for some control pictures.
RECORDED AS 50i (25 interlaced frames), I did sw deinterlace (AvidMC - fluid) for vimeo, so some fine diagonal lines can have a problem (see the blue locomotive at the beginning of the video, the rest looks ok). I made only quick color corrections for normal3, cine1, WDR and canon-log gamma curves.
The result of test is ok for me, I'm satisfied with a quality the internal AVCHD record. I see some banding on the sky at a last part of this test on the fine gradient (on the sunset sky) but cine1 and normal3 gamma look to be OK. This banding is from the 10bit A/D converter and from the 8bit record, cine1 gamma is ok for me (XF100 with cine1 gamma is also ok).
I tried various moods of colors at sunset at the end of test. Working with C100 is a very pleasing thing, because it is lightweight and a very powerful camera with good ergonomics. In sunny days is a good idea to connect an alphatron viewfinder, this help a lot. The rough sound is from the ME64 Sennheiser mic (A1) and from the internal mic (A2). The second part will be about evening - a lowlight with the C100 (with Canon EF 50mm/f1.4 , Tokina 11-16mm/f2.8 and EF-S 18-135mm/f3.5-f5.6).
I need a better glasses .-) .
