moldcad
With my 2 Canon EF lenses on Speed Booster, it's easy: I can use the IS switch on the lens, and forget about the camera menu setting. However, with the kit 28-135mm lens, it's not that obvious: the lens does have the OIS switch as well, but I'm not sure whether it works both ways on its own, or in unisono with the menu setting...
Checking whether the IS is on on the kit lens by listening to the noise inside the lens is difficult too, as the noise - though present when IS is on - is sooo much less pronounced than on the Canons. So, my questions is:
- with the kit lens, when I need to be 100% sure OIS is turned on (or off) - do I also need to set it in the camera menu, or is using the lens switch enough just like on the Canon EFs?
Piotr
PS. This is important, becasue if the physical switch is enough I''d have one User Button free for turning scopes, or High/Low key...
Piotr
