A couple of questions
flinty
Is the 14-140mm gh2 lens classed as wide angle because i get a lot of the affects described in this copied writing
f all you shoot with a wide angle lens are landscapes where the subject is out at infinity (let’s say, where the little blue lines, that symbolize the angle of view, end), there would be only a few differences. But those few differences can be important, so let’s go over them.
Light rays from the edges of the image are going to be bent a lot more passing through the lens elements in a wide angle lens than in a telephoto lens. This can cause more chromatic aberration if the lens doesn’t correct for it well. A good ultra-wide lens must have aspheric elements to correct for CA—an important thing to check for when choosing an ultra-wide lens.
The extreme bending of light rays makes ultra-wide lenses to vignette (have dark corners). It’s like gravity—you can’t change it, you just have to live with it. Some lenses and (because of microlens arrangements on their sensors) some cameras are more prone to this than others.
The sensor will “see” a lot more objects than usual. This means auto-exposure or white balance may be off. Wide angle shots with lots of bright sky often underexpose, because the camera is averaging all that bright sky in when calculating the exposure.
Because the lens is so wide, the sun (or other bright lights) will often be in the image. Good flare control is more important in an ultra-wide lens than in other lenses.
Because the angle of view is so wide, the angle at which sunlight enters the sensor will vary from one side of the image to the other, unless the sun is behind you. For example, if the sun is to your left, the left side of the sky will appear lighter and less blue than the right. Wide angles love overcast days and lots of clouds. Pure blue sky—not so much.
A polarizing filter only polarizes light entering at certain angles, so it can actually make this phenomenon worse. Unless you absolutely need it, a polarizer is generally a bad idea on an ultra-wide lens.
Back to myself below
Also on certain clips there is slight blip or momentary sound loss at the start, this does not happen all the time making me wonder if something is wrong.
