I love reading about HDSLR cameras on various forums. And the amount of FUD I encounter often baffles me. One of the things you will most frequently hear is how much the H264 codec of 5D and 7D sucks and how you can't grade it.
We all know that you can't grade 5D/7D footage to the extent you can grade Redcode RAW. But way too many people outright refuse to even look at the facts. Most of the people who shoot down the codec haven't ever tried to push it in post. So here we go.
I don't usually grade to an extent at which the grade turns into a special effect. I like to keep it subtle. But in the below example I changed the entire mood of the scene significantly. So it should be an interesting example.
Some quick info on the clip itself: it was shot on the 5D with the 24-105, sharpness turned all the way down, locked off on a tripod.
Let's start with the full resolution 1080p images for your reference:
Unaltered
Graded
Sharpened
Grain Added
DVD Resolution
This is how the clip looked out of camera:
The first thing I do is grade it using a variety of filters:
Next up is the crucial step of sharpening the footage. I use a two-step approach. To increase local contrast, I first sharpen with an extremely large radius and a low intensity. To increase detail sharpness, I then sharpen with an extremely small radius and higher intensity (left image is graded, not sharpened - right image is graded and sharpened twice):
If you take a close look at the full resolution images, you will notice that the sky shows a bit of posterization. To my eyes, this is the only visible compression artifact after this heavy grading. What I like to do is add some extremely subtle grain. It makes the image look more organic and less sterile, and it hides compression problems:
I also often read how 5D/7D footage is barely better than SD. So I scaled down the final image to 720x486 (SD DVD resolution) and back up to 1920x1080 as it will be displayed on a 1080p screen (left = graded HD, right = scaled down and back up):
And finally a comparison between the original out of camera image and the fully graded HD shot:
I will not comment on those results, you be the judge.
Unaltered
Graded
Sharpened
Grain Added
DVD Resolution
