7Q monitor calibration controls
my bad. maybe we're getting way off the premise here...
bottom line, if i trust my camera's viewfinder for color, the monitor its feeding should be at least that accurate if not moreso.
i have an eyeone pro color meter. I can measure it if i can connect a bluray player to the hdmi feed. Its nice that we finally have controls over those setting. I owned a smallhd dp4 , dp6 and 2 AC7s. All needed calibrating and was more pleasing to my eye using the eyeone pro. the biggest part is getting the grayscale on the monitor calibrated.
:) ill have to dig up my meter now and see how off it is.
Rather than speculate, I suggest everyone take a few minutes to try out the OLED calibration controls for yourselves. You can't mess anything up -- there's a RESET button in the top corner of the menu to take you back to factory default. Again, I personally found that dropping the Green Gain down to about 93 did it for me to match some other pro monitors I had to deal with.
Just be sure to eliminate all the other variables you may encounter -- use a proper quartz tungsten lamp at 3200 Kelvin with the camera set to a preset or do an white balance off a gray card, shoot a chip chart or a bowl of assorted fruit or some other image with a decent rainbow of colors, maybe get some attractive flesh tone in there as we're all very sensitive to that. There are two possible goals you'd likely want to reach: either make the image look as accurate as possible to your eye compared to the reality of the scene, or make the Odyssey's OLED panel match as closely as possible to other monitors you will be using. These are most likely not the same thing but you have to decide what is most important for your use.
In my case the green tint flickers on and off - which is a bit weird. I was going to put in a report to CD about it but never got round to it. Also, anyone notice how the backlight drops to low (if set to medium or high) when you hit record in 4K to 4K or4K to UHD mode. I'm assuming it's a power saving thing.
That happens if battery voltage is below 9v I believe, it is because the amp draw is high in those rec modes. I have found O7Q uses about 18w in those modes. So CD is protecting your battery, and making sure recording is not affected.
If you use 14.8v batteries this will not happen.
I have never seen green flicker, I would contact CD.
yeah, I assumed it was something like that - I was just too lazy to hook it up to a v-lock to check. As regards the monitor flicker - I was going to contact them, I just never got round to it. Although I'm not sure there's much they could do. It doesn't affect recording and I can't afford to be without the monitor for 2 weeks should it need to be sent to them for repair (not would I want to pay for shipping).
i cant calibrate because i dont have the right hdmi connector. the 7Q is using the medium sized hdmi connector which i do not have right now. anyone know what that hdmi connector is called? mini hdmi? ive seen even smaller hdmi but not like this.
I've heard the terms Mini HDMI and Micro HDMI. I'm not sure if these are industry terms or just informal lingo, but Micro is smaller than Mini.
ill go to cables and connectors tomorrow morning and see if they have a mini-hdmi to hdmi cable so i can calibrate the 7Q. A good friend on the AVSforum.com hooked me up with the software link to the calman 3.6 which i had lost due to a laptop upgrade.
I played around with the settings and I must say the standard is not far away from the FS700 LCD.
saturation 47%
contrast 56
r gain 98%
g gain 98%
b gain 100%
but as long there are no loadable LUTs the desaturated sLog image is no reliable reference point
saturation 47%
contrast 56
r gain 98%
g gain 98%
b gain 100%
thats why you should use a meter to measure and not your eyes, no one should use their eyes.
If you choose to match by eye I would certainly suggest using a fully saturated image in a REC709 color space rather than S-Log2.
I picked up an hdmi to hdmi mini today and will start calibrating the sweet OLED panel soon. working on a hydroponic system for fruits and vegetables right now. i love growing food!!!
i cant get the bluray player to output any image connecting to the odyssey 7Q. I checked the odyssey menu settings looking for an hdmi input setting but thought just plugging it in would automatically work. Any ideas? Mitch?
