Ryan E. Walters
I thought some of you may find the results of some testing I did this last weekend interesting- have a look: http://www.ryanewalters.com/Videos/Tests/tests.html
Ryan,
A great test result. I cannot comment on 7d since I don't own one. But I can say I'd agree with pretty much everything you said about d7000 and gh2 with exception of one correction about d7000. You can't change aperture with G lenses in live view mode, but you can change shutter speed in live view mode.
Thank you for sharing your test result with us.
A question. When you said d7000 was least affected by rolling shutter, you meant when shooting in 24fps, correct? gh2 and 7d can shoot 60fps at 720p and I would assume 60fps minimize rolling shutter effects on both cams.
Bumki
im pretty sure you made a mistake when you state that 7D, outputs SD, when connecting to a monitor. In fact the 7D is the only Canon dslr as far as I know that monitors in HD through hdmi. Just thought I would point that that out.
Thanks very much for the test. It is unfortunate that it seems that most people are not interested in doing test of the gh2. It is a shame because it is really another step in the hdslr revolution (no moire, aliasing, true hd video). The test I was really waiting for was the dynamic range test. What I don't understand is the disparity in the measured dynamic range. One of the best site testing the dynamic range is provideocoalition . With test ranging from the Alexa to the Canon 5d. They see the 5d (which I have seen quoted at about the same than the 7d) more in the 10+ reading. The single camera test done buy zacuto was more in the 11.3 stop, the nikon was much lower (even that in photographic terms it is about 14 stops in RAW!!!). Is it the chart... provideocoalition uses a baclit chart. I am in no way criticizing your test, all the contrary, I am grateful, more so because for once I can see a comparison with the gh2.
