7D Unknown Artifacts
nickylund
Not quite sure what is causing this:
http://farm5.static.flickr.com/4024/4365289135_a75aa4e91a_b.jpg
It's a still taken from a 1920x1080 23.97 video.
Shot at 3200ISO
50 shutter
2.8 apeture
36 frame pan
The light pole and other vertical lines have a duplicate image during the pan.
I thought it might be the firmware and the ghosting issue I read about since I hadn't updated to the latest version. It doesn't look like regular rolling shutter issues.
I haven't had a chance to go back out and run some more tests.
Any ideas?
Thanks!
1/50 is long enough shutter speed to let street lights (and fluorescents) go through 2-3 cycles during exposure if you are in a country with 60 Hz AC. Use 1/60 instead in situations like this.
Never ever ever ever ever ever ever ever ever ever ever ever ever use 1/50 on an NTSC 7D or 5D or GH1.
Just don't.
Please.
All of a sudden I feel stupid. But I have been using 1/50 shutter for video because i was told that's close enough to 1/48 (which it does not have). So, should it be 1/40 all the way?
1/60 if you want to avoid problems.
1/50 if you like problems.
1/40 if you like more blur, and should also avoid problems.
Just to add to Barry's information. Yeah, if you're shooting under fluorescents or light fixtures that don't have a proper flicker, just bump up to 1/250th and see if you see strange artifacts. If everything is good, then like me, you pretty much want to emulate 1/48th so you can take the risk and shoot at 1/50th.
I can see a subtle difference between 1/60th and 1/50th, and after these discussions i will seriously check more accurately by upping the shutter to see if artifacts are present, but if you're good then i see no reason why not to shoot at 1/50th.
Not to be a pain Barry :)
Hey Barry,
Can you elaborate on those problems? I have been shooting for months with the 7D, 23.98 and 1/50 shutter - I have not experienced anything out of the ordinary.
I never had problems with 1/50. but this gives me the idea to switch to 1/60 if i encounter these problems
Like with any rule -- if you know WHY the rule was instituted, and you know what circumstances caused it to be instituted, and you're certain that your intended use falls outside those circumstances, then sure, go ahead.
Just remember that you only have yourself to blame if you forget!
But what needs to happen is we need to exterminate this idea that "1/50th is the right shutter speed because it's more filmlike" idea that folks have. 1/50th can cause damage to people's footage. Every NTSC shooter should just default to 1/60th unless they know for absolutely sure that 1/50th is "safe" in their particular shooting circumstances, and that they actually care about the tiny differential in image look between 1/60th and 1/50th.
There, I fixed it for you.
Shooting 1/60 in a land with 50 Hz AC cycles can be just as destructive to the footage as shooting 1/50 in a land with 60 Hz AC cycles.
Considering how often this issue pops up it might be a good idea with a sticky of this subject in at least the general DSLR section, if not in all the camera subsections.
yes for us from PAL land, there really is not much viable option besides 1/50 at all. even 1/100 is problemeatic on fast ballast type of lights.
there is this bar with tri-colored 12V leds that would strobe at every shutterspeed available on the 5D because it is 30p while it is perfectly fine with the 7D at 25p.
some tests from 50Hz ligths
http://vimeo.com/4972364
http://vimeo.com/4991966
Excellent videos, thanks for posting those.
Folks, you have been warned. If you're in NTSC territory, put the shutter on 1/60th. If you're in PAL territory, put it on 1/50th. Anything else can lead to trouble.
I vote for a fully fledged PSA talking walk-on-the screen flash announcement for the forums, Barry.
The camera file is transcoded to Pro Res and then I'm pulling the still from Nuke.
But I can see the artifact in the H264 .mov file that came straight off the camera and in the viewfinder during playback.
I'm using the EOS Utility to bring the footage off the camera if that helps.
