E etrust Well-known member May 20, 2011 #1 Hi Guys, I'm using a 7D and a 17-55mm 2.8 77mm. Is there any reason to NOT use these 3 filters at the same time for a very brigh situation like in the beach: 17-55mm + nd 102 B+W + nd 103 B+W + Circ pol filter What could be the negative side? Would you do this?
H hafssol Member May 22, 2011 #2 Hi, when you stack up several filters lens might vignette at the wide end. Also, when using several neutral density filters, you should take IR contamination into account ...
