Is exactly what it is.Conventional wisdom would suggest that this relates to the users -- that 7D users are more likely to know what they're doing and are probably using better lenses.
It depends in your budget. I guess if you are asking this is because you only plan to take video. At current developing speed cameras last for half a year or a year, so save yourself some money and get the 550d. Specs for video are the same. Skew seemed slightly better. It's lighter which i like.
If you plan to shoot sports or journal photos, then the 550d is out of the question of course.
Intermediate iso values have proven not to be a good idea anyway (less dynamic range). Lighter is always better (ie:red1 vs epic or 435 vs 235).![]()
According to Canon the T2i/550d sensor is "based on" the 7D, not identical.
The 7D has dual processors, the T2i has one.
I've handled both -- and the 7D feels like a real camera, whereas the T2i feels like something you'd give your daughter for her photography class.
The sample videos posted online also aren't turning out identical. Conventional wisdom would suggest that this relates to the users -- that 7D users are more likely to know what they're doing and are probably using better lenses. This may be true -- or there may be more too it.
Bottom line -- the T2i is among the most revolutionary consumer cameras ever offered. For professional applications -- I'd feel like a fraud showing up at a pro shoot with a T2i in hand. And, despite what the justifiably enthusiastic T2i owners are saying -- I'm really not convinced the video quality is identical.
:2vrolijk_08:According to Canon the T2i/550d sensor is "based on" the 7D, not identical.
The t2i vs 7d argument has turned up many times on these forums and there really is no positive answer.
Also people get argumentative very fast as investments have been made and must be justified.
Lets all be careful and constructive in the way we word these posts.
Cieloent --
What's "comical" is the substance you cite is a Phillip Bloom video. Have any videos of your own? Do you know the difference between eight frames a second and three? Have you had a T2i overheat on you in half the time it takes for a (pre firmware updated) 7D to flash the warning?
The only issue with the intermediate ISOs is that its easier to clip the highlights in contrasty scenes. They are perfect for controlled environments....like shooting indoors in moderate to lowlight lighting. There are no issues with dynamic range because your scene is not so contrasty. In these situations you can sometimes run into the problem of noise in the darker areas but ISO 160, 320, 640 etc. keep it clean for me. You don't want to use those ISOs outdoors when it's bright and sunny...or shooting with a bright window in the background etc.I also asked about the difference with these cameras and I got some answers from macgregor which really helped.
Every single side-by-side test that anyone has ever done with the T2i and the 7D has clearly demonstrated that video and still quality is identical (or near identical enough for the difference to be utterly insignificant), at least up to ISO 1600. Of course, I don't have links to these tests right off-hand, but they shouldn't be hard to find. You are free to dismiss this statement for my lack of cited evidence, but let me remind you that your point was made to raise fear, uncertainty, and doubt with only intimations. You tried to suggest that the video quality of the T2i could be inferior by comparing two completely different (and therefore incomparable) sets of sample clips. To an objective observer, there would likely seem to be a bias lurking. So unless you're willing to make a clear claim and support it with reasonable evidence, then I respectfully suggest that you withdraw your point.And, despite what the justifiably enthusiastic T2i owners are saying -- I'm really not convinced the video quality is identical.
Just to be clear, are you speaking from personal experience? The OP needs a straight answer.Have you had a T2i overheat on you in half the time it takes for a (pre firmware updated) 7D to flash the warning?
As this post is directed towards me ....
