I accidently shot some footage at 24p instead of 24pN this would be the first time i have made the mistake and need to standardize it with other clips at 24. I did some research and no to do a 2:3:2:3 pulldown you have to use Cinema Tools. Problem being after Logging the footage into FCP the Vid Rate is 59.94 and Cinema Tools will not do a reverse telecine citing "NOT an NTSC format"... Any experience from some more experience members.
THE STATS
I have footage shot 720p 24p.
Final Cut is 6.0.4.
Vid rate of converted footage is 59.94 fps.
Remove Advanced Pulldown and Duplicate Frames is checked off (though when checked on I get 23.94 rate but always heard FCP couldn't do it accurately so i'm worried about quality loss)
THE STATS
Final Cut is 6.0.4.
