srfer919
After browsing the forums, I am still having a problem with this process. I've been experimenting a lot and to no avail.
I'm using FCP 6 and Compressor. Source material was shot in HDV 60i, at 1/120.
I don't understand what I'm doing wrong. In compressor I use the 1080i60 quicktime codec, set the framerate to 59.97, turn all frame controls to best settings, and output fields to progressive. Am I using the wrong codec?
Now, assuming I correctly converted the 60i in compressor, I drop the 60p into a 24fps timeline, and set the speed to 40% with frame blending off and render. Once it's done, I preview the footage frame by frame and Im still gettting a bunch of copied frames. Each frame is not unique.
Any help would be greatly appreciated.
Thank you
Thank you
