Hi swyzlestyx, try to use vegas 10, it optimized for avchd. So far work smoth on timline. Cf is nice but add extra step to workflow and make big file. Not bad!
Thanks guys for the info. I am also using Vegas 8 (mainly because my copy of Magic Bullet won't work with Vegas 9 and up). I will consider picking up a copy of Cineform.
How about the higher bitrate Motion JPEG files produced by the GH13? Easier to edit than AVCHD? Any place we can download raw files to sample?
Yes, Vegas Pro 10 has been optimized for AVCHD and other H264 variants (e.g. from Canon's DSLRs). My aged dual core PC (Intel E6300) can play through these files at full frame rate. The trimmer is another matter though, it's pretty chunky. I'm building a new system though (i5 2500K), which will hopefully make for a smoother workflow. Anyone have experience with i5/i7 in the trimmer? Good times? Fast forward and rewind smooth?
I considered Cineform, since it can be had for only $90 (at Videoguys w/$10 coupon code "REGTEN"), but I decided against it because of the increased file size and transcoding time.
I'm a little late to the party but have a question...are your AVCHD files on an external hard drive connected via firewire or USB 2.0?
I am on a quad core witrh 4 megs of ram, running Vegas 10.0e and all AVCHD files are on a HD connected via USB. Playback is very stuttery and I've been told to move to an esata raid which should make life easier. It's a bit confusing as some people here have no issues and others do, all things being somewhat equal.
Any thoughts would be apprecaited.
External USB drives are too slow. Your files need to at least be on an INTERNAL hard disk if you want to work directly with AVCHD files. Esata raid would be better too.
For those who have not bought a good editing program yet - GRASS VALLEY EDIUS can handle AVCHD files with no problem on a decent PC.
