600D + cinestyle = vertical streaking???
jenningsp
just bought a 600d and loaded cinestyle. any time i have something underexposed in shot. like a dark grey i get these very visible vertical lines...
is this just how cinestyle is? or is this just the 600d + cinestyle? or is my 600d faulty?
here's a pic. i've increased the contrast and saturation so you can see it... but in moving picture they're static so you can really see them if you pan...
I use a T3i and Cinestyle. I've never seen anything like that. What lens and settings are you using?
It's normal, you shouldn't underexpose it a lot. Use a higher ISO instead (this applies analog gain instead of digital, and is much less noisy). You may also shoot a dark frame and subtract it.
tune off the "high tone priority" will greatly reduce that problem
I dont find the Cinestyle use in most conditions because it boost the shadow too much
the hardware just isnt good enough.
