5d easy setup settings
Hello,
What is the ideal easy setup settings for FCP 7 for use with the Canon 5d.
I tried using the search engine but to no avail.
Thanks,
A
That's not what I'm asking, but thanks for the replies.
I need to know what easy setup settings I should put FCP7 in for editing footage from the 5d.
I've used the EOS plug in and it's great.
A
It may be that you need to customize your settings, rather than use an easy setup. Your capture and sequence settings need to match the codec and frame rate of your footage.
