daveswan said:As THoff said, it's very simple realy, the image is captured as progressive, so you have a complete frame every 1/25th second, but this has to be split over two1/50th second fields, but they come from the same frame, so you don't have interlace problems.
When I capture this footage into Avid, I set the project type as PAL 25p.
BTW, the same thing aplies to the 1080 footge.
HTH,
Dave
Just look at the footage. It's night-and-day different from interlaced.GuanoLad said:??? What's the point of Progressive mode then?
Cees Mutsaers said:Thus in the NLE system the 25 progresive frames are split into 2 times 25 frames.
No, not really. If you were editing in a 50i timeline you'd still be dealing with 25 "frames" because NLEs don't let you edit at a field level; they always group fields together into field-pairs (or, more commonly, "frames").So on the timeline you have 50 frames namely 25 with the even and 25 with the uneven lines (of coarse in pairs) right???
If you put 25p footage on the timeline, you would be doing yourself a big favor to choose a 25p timeline. You could cut it on a 50i timeline and it would work, but any graphics or titles or transitions would look much better rendered at 25p than they would at 50i.If you load 25p recorded footage into the NLE you have to choose 25p (and not 50i) and internally the frames are split into the 50 half frames right?
You can render a 25p sequence from your timeline. But here it diverges from the way NTSC works. In NTSC DVDs you can export a true 24p sequence that will actually be encoded as 24p and live on the disc as 24p and played back as 24p (unless you're outputting to a CRT, in which case it'll split it back into fields and output fields with pulldown). I don't know if PAL DVDs can store a pure 25p signal or not; it may be that the output 25p from the timeline actually lives on the DVD as 50i. I'm not sure.But what happens when you after doing the edditing burn your project to a DVD? Are the 50 frames combined to 25 P frames again before it leaves the edditing system onto the DVD, blue-ray etc. ???
In 24P, yes. Not sure about 25p.edit : in other words are you burning progresive images (25 full frames/sec.) on a DVD?
Completely agreed. On the DVX they never made mention of 480i/24p, they just called it "24p". On the HVX they went for "full disclosure"; it's probably caused more confusion than any other single item on the product.GuanoLad said:My suggestion is they don't confuse the issue by referring to it as '576i' and maybe just use '576' only.
Barry_Green said:If you put 25p footage on the timeline, you would be doing yourself a big favor to choose a 25p timeline. You could cut it on a 50i timeline and it would work, but any graphics or titles or transitions would look much better rendered at 25p than they would at 50i.
Barry_Green said:In NTSC DVDs you can export a true 24p sequence that will actually be encoded as 24p and live on the disc as 24p and played back as 24p (unless you're outputting to a CRT, in which case it'll split it back into fields and output fields with pulldown). I don't know if PAL DVDs can store a pure 25p signal or not; it may be that the output 25p from the timeline actually lives on the DVD as 50i. I'm not sure.
