If we'll use a 5400rpm only for OS and running our editing and color correction apps
...is a 7200rpm disk strictly necessary?
(the idea would be to only use external 7200rpm disks for storage)
And if without Express Card Slot? Can a USB 3.0 or eSATA port work the same for a 64GB SSD to run the apps?Actually you should be doing the opposite and run the Apps on the 7200 RPM HDD and use the 5400RPM for storage. Now if you really want to get fancy on the cheap you can use your Express Card Slot and add a 64GB SSD and run the Apps, for under $200.00
Why expresscard? I dont know of any expresscard SSDs that can compare in speed or price to modern 2.5" SSDs. Why not just swap out the SYSTEM HDD for an SSD? Then use HDD for storage. This is how I have my workstation set up.
