Anders Holck
I'm wondering a bit about the 50p version of the 720p codec. To date no product has used this codec, only DVCPRO HD 1080/25p has been utilizized. And I havent found any info anywhere on the specs. All whitepapers mentions three DVCPRO HD codecs:
720/60p
1080/60i
1080/50i
So what will Panasonic implement for the DVX200e?
The 1080/60i codec is 1280x1080 at 30P and has a bitrate of 100 mbps (6.7:1 compression)
In the 1080/50i codec, to keep the 100 mbps and the 6.7:1 compression at the lower framerate of 25p, Panasonic raises the horisontal resolution to 1440 pixels.
The 720/60p codec is 960x720 at 60p using the 100mbps bitrate
So the question is what will 720/50p be:
- will it be 1280x720 to keep the the bitrate at 100 mbps (most likely)
- Or is the compression lowered to 5.58:1 (HVX-200e pdf specs says 6.7:1 compression in HD)
- Or is the bitrate lowered to 83.3 mbps (HVX-200e pdf specs says 50p at 100 mbps)
Does anyone have info about this?
720/60p
1080/60i
1080/50i
