50/25p FCP
morgan_moore
Major Contributor
Hi
Ref FCP
IM trying to do some slomo having milmed at 25 and 50p
I read some where 'just retime on the timeline' ie change speed 'no blending' or whatever
that does not work gets jumpy footage.
Im now doing it in compressor, looks like an overnighter
So is there a good workflow, maybe ustilising Mpeg streamclip
for fast and proper 50/25 ?
Also Im not sure how to tell which clips are what speed - what I did was shoot my slomo section on a sperate card - is there another way??
S
Hi there morgan use cinematools to batch conform your 50p clips to 25p it should take a few seconds. However, once you change your clips to 25p they stay that way ie 50% slomo. However, I dont know why anyone would want that awful hyper reality 50p look! Hope that helps
If you want to preserve the original footage just make a duplicate of it and then use cinema tools like sam mentioned. Everytime I use cinema tools to conform for slo-mo it works perfect.
I may be being really thick
Cinema Tools ? Im using compressor - totally wrong??
the look im going for is slomo - is that bad in your eyes
S
Morgan I think he means 50p when not conformed for slo-mo looks hyper-realistic.
You have the Final Cut Suite correct? There is an application called cinema tools that allows you to conform footage to various frame rates in a matter of seconds.
Basically you open the clip with cinema tools and there should be an option in the window that says "conform". It'll then show you the current frame rate and give you an option to switch it to 25p, 24p, 23.98 etc.
I don't have it on my work laptop, otherwise I'd include some screen grabs.
wow that saved me about five hours !
Thanks - I can now check out some slomo
BTW compressor up pitches the sound if you have hours
S
