4k Camcorders - which features do the cheaper models lack?
Vic5
I was looking at 4K camcorders. Some seem to be available at a much lower price. Sony has AX33 as low as $1000. There are limitations with the lenses and the codec I understand. Which features would you say are most commonly compromised on, in the lower priced camcorders? If you had to choose a value-for-money 4K camcorder which was not necessarily the cheapest, for shooting narrative fiction films, which one would you pick? I hope this is the right sub-forum for this question because it isn't only about Sony.
I want a reasonable range with the lenses, an edit-friendly codec and the ability to record with enough information, so I can do a clean keying-in for chroma key.
Thanks!
I'm sure you are gonna make the right decision, and I'm sure you'll make it work for you.
That said, the priority on 4k for me can sometimes take a back seat if it comes to making the best looking image. There are so many things that go into making a great looking image, other than resolution...as you probably already know. The only reason why I'm saying this is because I personally would rather have a great 1080p image, heck, even an amazing 720p image, over a mediocre 4k picture. Ok, maybe the 720p thing is a bit of a strech. But color science (since you won't be shooting raw), motion cadence, lenses, a good color sampling and not overly sharpened image is the priority. Resolution is only good if it is comprised of all these things.
For $1K you're better off with a bargain F3 or even a BMPCC. Both will allow you to put glass with character in front of your sensor.
Here I am talking all this stuff, and I actually don't know what you intend to even do with a video camera. For all I know, you need zoom rockers and auto-focus. :)
Most less expensive cameras that shoot 4k are using an 8 bit 4:2:0 codec. That's not a good codec to do good grading and FX work. Even Sony says their new FS5 $5500, which is 8 bit 4:2:0 in 4k, is NOT a "cinema" camera.
If you want a camera that has good cinematic and grading potential with an easy to use codec and a reasonable price, the Blackmagic Production Camera 4K would be a good choice. You can shoot in ProRes, a very easy codec to use and it's 10 bit 4:2:2 which is good for grading and keying. It's $2995.
I'm not sure why you need 4K? Future proofing, reframe, pan and zoom? 4k is not mission critical for cinema delivery.
You could get a Blackmagic Pocket Camera for $995. The aforementioned FS5 uses 10 bit 4:2:2 in HD. If you're OK with a fixed lens camera you could get the Sony X70 which uses the same 10 bit 4:2:2 in HD for $1999 and has a 4k option for $500 but it's 8 bit 4:2:0. The sensor is 1" even though the lens isn't fast at most focal lengths, you can squeeze out some reasonably shallow depth of field.
In short, if value is important for 4k narrative it would be BMPC 4K at $2995.
If 4k isn't important than the BMPCC at $995.
If 4k isn'd important and you're OK with fixed lenses (since you mention the AX33) then the X70 at $1999 would be good (and $500 for a 4k option but not an ideal codec).
@DLD
I realize the sensor is larger in more expensive cameras. Somehow missed to include that in my post!
@abreu-canedo
I plan to shoot a short and would like a camera which has an edit-friendly codec. Also need to be open to showing it in a movie theater.
@cseeman
I'll have to do some research about the workflow for Blackmagic Pocket Camera/Blackmagic Production Camera 4K. Maybe the Sony X70 could work. I could rent a camera when this one isn't meeting my requirements.
All options for me to explore.
Thanks!
The x70 is a completely different beast from the others, well maybe the BMPC as they share a 16mm ish sized sensor. For ENG style work where you want the ability to get a shallower depth of field the x70 is a good solution. Some people though have reported issues with injest into their NLE with the x70.
Renting is always a good idea.
Sony's professional XAVC-L and consumer XAVC-S should now work in any commonly used current NLE (current being important).
Vic5, you're really fuzzy about what you're looking for. Generally H.264 GOP based codecs are less edit friendly than I-Frame codecs. 8 bit 4:2:0 codes are not great for chroma key or color grading (common in narrative work).
That's true. I'm still evaluating. I definitely need an edit-friendly codec and one that makes keying-in easier. I have a T3i currently and chroma key work seems impossible or at least extremely difficult.
@Andrew Stone
The trouble is renting turns out to be far too expensive, where I am. For instance a Canon 5D MIII costs as much as $80 a day. It would take me some days to get acquainted with the camera. If I want to experiment, I want to have it available. I would rent a camera for a few days to be sure it will meet my requirement if I buy it. I do need a shallow depth of field for filming the short.
You'd want 10 bit 4:2:2 rather than 8 bit 4:2:0
Sony X70 or Blackmagic Pocket. The latter, with Canon EF SpeedBooster will allow you to use EF (but not EF-S) lenses.
Yes. I think I'll compare the cameras that can record at 10 bit 4:2:2. Thanks.
Thanks!
I'd rather give up 4K and skip the AX33 with its tiny as sensor and get the CX900! (which has a great 1" sensor, similar is in the RX10/RX100/X70/AX100).
But for your needs of chroma keying, I'd suggest getting at least the Sony F3 which can give you up to 12bit 444!! (or much more cheaply a recorder to do 10bit 422, which is likely more than enough for most needs)
I got my F3 for a crazy low price of US$1.2k back when they were going for far far more. But these days it isn't too hard to find one for US$2K (or even as low as US$1.5k with a bit of luck and patience).
Otherwise, to get such a high end camera at a low price you'll need to look instead elsewhere. With the best option being Blackmagic Design, though that would give you a different mix of pros and cons vs a Sony one.
One key one to check out is the Blackmagic Micro Cinema Camera, can be pre-ordered for only US$995. Or if you can't wait get the BMPCC (But the BMMCC gives global shutter and 60fps, so I'd wait if you can!!).
Or go for the URSA Mini 4K, which is a somewhat more expensive camera (US$3K) but gives you 4K. However.... I wouldn't recommend it over a BMPCC. As an URSA Mini 4K has worse low light and less dynamic range (two important factors here!). I reckon the BMPCC is the best camera BMD ships right now (and I own one of them too! :-D ).
