35mm ND Filters selection help (!!!)
Giovanni Bertani
Hi!
I am looking for some ND filters to use togheter with te following Nikon lenses and brevis35mm adapter:
ZOOM 70-210 mm 1:4 NIKON SERIES E
80-200 1:28 NIKON ED AF NIKKOR
35-70 1:3.3-4.5 AF NIKKOR
28-85 1: 3.5-4.5 AF NIKKOR
50 mm 1:1.2
I was wondering if it makes any sense to use a, quiet cheep, Cokin Creatve system adapter with separate rings for the lenses:
http://www.cokin.com/ico15-A.html
http://www.cokin.com/ico3-p1-2.html
And sun shade:
http://www.geocities.com/cokinfiltersystem/hood.htm
or to forget directly about this and find matte box. But with this I have not much experience... Any suggestion?
And last but not least... which ND filters I should buy as priority?
Cheers :2vrolijk_08:
There's a 35mm Adapter section on this Web site. I would suggest you ask your question there for a better response.
A quick answer based on my experience. You should look at 1 of 2 options:
1. Purchase 82mm filters, and then a set of step up rings that would work with all of your lenses. A .9 ND and Polarizer should be standard.
2. Use a mattebox and purchase 4x4 filters. A recommended collection of 4x4 filters would include a .9ND, Polarizer and Graduated ND. The graduated ND pretty much needs a mattebox so you can lower it to match the skyline, window, or shooting angle.
These 4x4 filters are fairly inexpensive (Cavision), and they work:
FTG4X4GD/0.6 (0.6 graduated ND)
FTG4X4ND09 (0.9 ND
FTG4X4PL (Polarizer)
Try adorama.com
