The new Letus Ultimate, which goes for 4400 USD, has a relay for b4 mount cameras.
Cinevate Brevis will have a relay for its Brevis flip with a tentative release date of November which will add 2200 USD to the current system.
I have recently got a set of canon EJ series primes and an hpx500, I am currently testing the setup, but I would never look back at the boredom of having a 35mm adapter in the loop! Digiprimes slot straiht on,no beeping ground glass etc!!!!! no poor construction issues, no grain appearing randomly... its all good.
Yes, and the very expensive 2/3" Cine lenses will give you the exact same DOF as any 2/3" ENG lens.
Might be a silly question but I genuinely don't know... when you film with the Letus 35mm adapter does the footage come out as 16:9 or the film size (I think it's about 2:1 or something)?
Just to add to this point, as avengelos added the information is not correct.
The Canon FJ lenses are a very good example of Cinema style 2/3 lenses, they are superior to standard lenses and offer better DOF because they are faster. But there is no free lunch, the imager is 2/3 and physics are still the same.
I like using this set because, they are identical in size and weight so when running a steadicam changing lenses does not mean re-balancing the entire rig. Same for on sticks, motor placement...etc
For film DOF you still need 35mm imager.
You can find a link to the canon line of prime lenses here:
http://www.usa.canon.com/html/industrial_bctv/pro_hdec.shtml
Oh, please.....
Letus and Cinevate are being SO silent about relay lenses.......
