Thomas Mathai
Gordon Prince said:As I already posted:
It seems quite strange that someone like Stuart English is speaking about 2.35 when the correct ratio is 2.39 if it is right.
If you scan a 35mm film that is shot 2.40 scope, you get 2048x1556, a full aperture scan.
Since scope is a 2 to 1 squeeze, Y= 1556/2 which is 778. Then you take off 220 off the left side of the image in X to take out soundtrack area.
You then get 1828x778 which is a 2.35 image. Since a 2.40 image would be 1828x762, you have 8 pixels top and bottom to play with.
You NEED to look at a sizing chart which lists different aspect ratios, a good chart will show you the action and title safe areas.
All your critical image should be within action safe, and all titling should fall within title safe.
Most major feature films shoot a sizing-focus chart that is digitally scanned and given to all involved in the post production, so they know what they have to protect for.
You really don't want to shoot 2.39 or 2.40 because that is the projection aspect ratio shown in a theater, which is tighter than what the camera aspect ratio would be.
Also you won't have any room for repositioning in case you need it.
Zooming into an image should be a last resort, even though you can zoom in as much as 40% before you notice image degradation.
An HD 1920x1080 image is a 1.77 aspect, and a 1.85 aspect of that same image would be 1920x1038, so that gives you 21 pixels top and bottom to fuss with.
I should charge for this stuff
