DavidBeier
If you shot 24p you certainly won't get motion that looks like 60i; it's just not going to happen. However, if you're mixing your pulldown then it wouldn't surprise me if you're getting some motion artifacts. If you're shooting 24pA the pulldown is 2:3:3:2. The NLE will just delete every third split frame to get a true 24p. In regular 24p however, you're only doing 2:3. The third frame is spread across two split frames and has to be extracted and rebuilt. If you're trying to mix that into a 24pA timeline, thenit means that you're just dumping the one of the split frames and then seeing only half of the origional 3rd frame. This could make parts of the motion look speed up as you describe.
In other words:
24pA:
A Frame (two fields), B Frame (two fields), Split frame half B half C, C Frame (two fields, D Frame (two fields)
The third frame is then dropped to be pure A, B, C, D, E, F
24p
A frame (two fields), B frame (two fields), Split frame half B half C, Split frame half C (other half) half D, D frame two fields.
Extracting using the 24pA pulldown however would give you:
A, B, Split frame half C half D, D, split frame half E half F, F
The result is that every other frame is being chopped in half. This will certainly look odd.
In other words:
24pA:
24p
