24p help pleeeeeeeeeeeeeeeeeease!!!!!
from Wikipedia:
Displaying 24p material
With NTSC equipment, it is impossible to display a 24p signal directly as the monitors only support the 60i framerate. Hence, pulldown must be added to the 24p material to be displayed. Most editing systems will either add 3:2 pulldown or 2:2:2:4 pulldown. In the 2:2:2:4 pulldown scheme, used as a choice primarily by Apple's Final Cut Pro, every fourth frame is repeated. This scheme is easier for slower hardware to implement as it requires less processing.
24p on DVD
DVDs, however, are capable of storing the native 24p frames. Every Hollywood movie is laid to disc as a 24p (actually 23.976p – see below) stream. With a progressive-scan DVD player and a progressive display, such as an HDTV, only the progressive frames are displayed and there is no conversion to an interlaced format – eliminating the appearance of any interlace or de-interlacing artifacts. When displayed on a standard NTSC TV (which only display 60i) the DVD player will add 3:2 pulldown to the signal.
In traditional television broadcast and VHS, the video stream has 3:2 pulldown added. This material cannot be displayed progressively without the resolution loss of de-interlacing, unless the de-interlacer has accurate cadence detection.
Most of what I do ends up on TV - so there's no point finishing in 24p. In this case, if I'm mastering to DigiBeta, I will shoot 24p or 30p and finish at 29.97 in FCP. If I am only shooting for the web, then yes, I will shoot and finish in 24p. And yes, if I am only outputting to DVD then I will shoot and finish in 24p. As always, it's best to first know your final output needs. I find that shooting 24pA is the best choice for me, because I can finish either in 29.97 or 24p, depending on how I ingest the footage at capture. Cheers!
