24F upgrade
naavt
Hi,
I'm thinking if the XH-A1 24F upgrade worths 400 Euro!!??
What are the main differences between 24F and 25F?
I also have another question. Besides giving 30F and 60i capability along with 24F, why is it called NTSC upgrade? Isn't it 24F universal? Didn't would be more correct to name it: NTSC 30F/60i and Cine 24F upgrade?
NTSC and PAL are two broadcast standards that are used in different parts of the world. In the United States the standard is NTSC 24 fps and 29.97 (60i or 30p) while in Europe it's PAL (25p and 50i). There's very little practical difference between 24F and 25F and if you're living in the correct territory (i.e you have a PAL camera in PAL land) then you don't need to get the upgrade. It's meant for shooters who does work that will be broadcast in both territories and need to switch systems as appropriate.
