Jonathan12uiz
Is the Panny Pancake lens' field of view optimized for the 2x crop sensor? Meaning it will give me the same FOV as a 25mm full frame? or is the image circle on the pancake still full frame style?
There is no such thing as "being optimized for a sensor". A lens delivers the exact same field of view at all times. And the sensor will "see" as much of that view as it sees.
Any 20mm lens will deliver the exact same field of view as any other 20mm lens. The "crop factor" has to do with the notion that the smaller sensor will only "see" a smaller portion of what the lens is delivering.
As such, the 20/1.7 will deliver a field of view that's about the same as a 40mm lens on a "full frame" camera. If you took a 20mm "full frame" lens and put it on the GH1, it would give you the exact same field of view as the 20/1.7 on the GH1.
Again, it doesn't work that way.
The EF-S lens is the same mm as the EF lens. If you take a 50mm EF-S lens, and a 50mm EOS lens, and put them both on the 7D, you'll get exactly the same image. If you put them both on the 5D, you'll get exactly the same image, except that the EF-S lens will vignette on the bigger sensor. But the image within that frame, within that circle, will be exactly the same on both.
The only "optimizing for a sensor" that gets done, is that on the smaller sensors, they design the lens less expensively because it doesn't have to cover such a large frame. But the perspective, field of view, and DOF characteristics are all the same.
The lens doesn't change, it's the size of the sensor that makes the difference. There is no such thing as optimizing a lens so that a 20mm on a 2x crop = a 20mm on a 1.6x crop or anything like that. It doesn't work that way.
If you want to look strictly at field of view, and ignore all other aspects of imaging, then it is always the case that equivalent field of view is achieved by multiplying focal length by crop factor. So if you want the fov that a 20mm lens delivers on a 1.0 crop, when mounted to a 2.0 sensor, you'd have to use a 10mm.
