20' Homemade Crane/Jib for sale - $250 obo
Hey, guys! First of all, I know that this looks sketchy as I just joined DVXuser, but I've been surfing this site for years and I've got a rep over at reduser.net. I'm making the jump to the RED camera, so I don't need my homemade DV equipment anymore, but thought that I could pass it onto someone else who would get good use out of it.
I'm selling my homemade crane/jib. It's made of 3 different sizes of 8' aluminum (1 1/2", 1 1/4", and 1" I think) so it telescopes inside itself. There is a ball bearing swivel mount that can turn 360 degrees that mounts the jib on the base. All other pivot points are high-quality bushings. I don't know the exact names because a friend supplied them from his engineering firm.
All of the joints are professionally welded and are very high quality.
The distance from the pivot point to the user/weight end is 4', and the minimum length on the camera end is 9'. The top 2 peices of aluminum can be extended to make a total length from the pivot to the camera of just a little under 18'.
It is built to support a Sony Z1U of about 5lbs. Weights are not included, but it takes 10-30lbs to operate at the different lengths.
The camera platform has a 1/4" hole on it so you can attach any tripod head you would like. I have an older head that's on the job right now, which you can have (I have lost the tripod plate, though).
So, as you probably know, a 20' jib made of aluminum can't support 5lbs of weight without sagging a little. The crane is a home-built device that works well, although it is not without it's limitations. You will NOT get professional-looking results at medium to high speeds with the jib extended 20'. Low speeds, yes. High speeds can be used with it at its shortest length.
Footage taken from the jib can be seen here: http://www.youtube.com/watch?v=-9aVg8sQPo0
It's rather bulky and really would be impossible to ship. I am located in Boulder, CO. Unfortunately, this really only applies to people who can come and pick it up.
Asking price is $250, but I'll take the best offer that comes (above or below.) It's possible everyone will want it and it'll be $700. It's also possible that no one will want it and I'll give it to you for a Chipotle Burritto. PM me.
The Crane all the way collapsed
The jib all the way extended.
The head. The head will stay parallel with the ground.
Where the aluminum telescopes. Simply remove the screws and nuts to extend.
The pivot point. Notice aluminum welding.
The user end. Unscrew nuts to fasten weights between washers.
$250 for that?! Look at how much it is bending! I found a site that has a much better made and much more professional looking one for $300.
a 20' one WITH a tripod? i doubt that because i was in the market for a jib for a while and did much research on these over the course of about 2 months. i think this is solid for being homemade too, props.
You did a nice job...but at the price metals are getting these days, you might be better off selling the aluminum as scrap? Just an idea...
make an offer then!
make an offer then!
If you don't think it's worth $250, just make an offer. It's got over $150 of raw aluminum in it, so I thought that all of the engineering and labor and misc bushings/bearings were worth at least $100, but if you don't think so... name another price! I just want to get it out of my garage.
Ryan
ok final offer, 3 Burrittos, 2 tacos, 1 bag of chips with salsa and guack, and a soda, but that has to include shipping.
Ryan
Selling homemade/DIY gear is not allowed in the marketplace.
Not entirely true.
making of gear and using the marketplace to "operate a business" by reproducing it and taking orders and selling more than one is not allowed.
Wanting to get a diy product you made out of your garage is allowed.
Private, individual sale of products is allowed. Doesn't matter if it's a name brand, something you made that you no longer have use for, something some other diy'er made and you bought it from them, etc.
The only distinction that needs to be made is does something violate forum guidelines (advertising policy). That applies to all areas of the forum. No special rule about diy stuff in the marketplace other than that which can be easily covered by the forum's advertising policy.
It's quite obvious what this particular thread is in my opinion.
No worries to the o.p.
Later,
Jason
No it is a little under 20 feet and has no tripod. Although it looks billion times more professional, can fold up into different pieces to carry easy, and you can set up in about two minutes.
http://www.dvxuser.com/V6/showthread.php?t=102996
"--If you're not interested in the item(s) for sale please do not respond or reply in the post."
If you don't want it or like it, that's fine. But there's no need to jump all over the guy. He is up front about its limitations and that he's willing to take BO.
I make a lot of my own gear, and whatever the limitations of this, it's obvious to me that he put a lot of time, effort and some cash into it. Cut him some slack.
