2 Sony PL mount Zoom lenses and Cooke i/data
LuckyStudio 13
The Tapeless One
Sony’s F3 Camcorder uses the same CMOS image sensor as the NXCAM 35. It measures 23.6 x 13.3 mm, with a 27 mm diagonal — 16:9, APS-C format. At NAB, expect to see an RGB 4:4:4 and S-Log (Sony’s gamma curve) output option up to 30 fps, and SStP (Simple Studio Profile) 4:2:2 up to 6o fps.
You’ll be able to record onto the new SR Memory Cards using Sony’s new portable SR recorder. I’m sure we’ll see various mounting rods and brackets to make this possible.
Two new zoom lenses are planned for the F3. Coming in the 2nd quarter of this year will be an 11 – 16 mm T3.0 PL mount zoom. It’s expected to cost around $7,000.
A second zoom is expected later in the year: 18-180 mm (10x) or 18-252 (14x) mm. Maximum aperture will be around T3.8. Depending on how small it is, I expect there may be ramping of the aperture. The zoom certainly will be small, taking advantage of the F3′s very small flange focal depth. It will also incorporate electronic contacts and zoom control via the rocker in the F3 handgrip.
The next firmware update of the F3 is expected to be able to manage Cooke /i Data.
EDIT:
Just found the above information on Film & Digital Times. The 11-16mm lens is a PL mounted one. The other lens, it is unclear, according to the article.
The current F3 supports Cooke iData.
Also, why would a person pay $7,000 for a 11-16, when Matthew Duclos makes a 11-16mm T3 for $3500, PL mount.
I think they are suppose to release a zoom lens which works with the zoom/tele rocker switch on the camera handle. Hopefully Q2 of 2011.
Ryan that's how I remembered it as well. Jon Fauer got his information directly from Sony in Japan during his visit to their high tech silicon fab facility. Looks like Sony has rethought a bunch of stuff.
And that's the great thing right now! Chouces, choices,...
Same optics can be purchased for $600 from Tokina (no PL mount, but we all have mtf adapters: right???)....
This was to test aliasing, but the wider shots in the end of the clip are on the 11mm.
You paid $8,900 for an 18mm prime. :)
...As did I. :)
hahahahaha!
I used this example to answer your question. You'll pay for what you get. Duclos's lens is a good one. Perhaps the Sony will be better. I'd at least look at the $7,000 and compare it to the Duclos and I'd also gladly pay the extra $3,500 if it were noticeably better. However, if the zoom resembles the Sony PL lens set in any way, shape or form, you'll see me running in the other direction. Sony has done everything but impress me regarding their lenses.
If that's true, it won't be a PL mount lens. There won't be a PL mount lens with internal servo-zoom mechanics. Not sure if they even could do it through the Cooke/i port.
