Mike Krumlauf
Award Winning Filmmaker
it would be nice if someone could make a hack so there could be an in camera mask for 2.35 so i didnt have to gaff tape the lcd when framing. it gets old :lipsrseal
That's effectively what my Anamorphic 1920x810 Cinemascope Patch does in MJPEG mode, with the added bonus of natively recording an anamorphic 2.35:1 image for you! With this patch, what you see framed in the viewfinder is exactly what you get:it would be nice if someone could make a hack so there could be an in camera mask for 2.35 so i didnt have to gaff tape the lcd when framing.
Understood, and I know I'm not making it any easier by scooping up the few anamorphic bargains that show up on ebay:...your patch is great, but the one major downside is that we can't shoot @ (AHCHD) 24p with it.Plus, we need to use an anamorphic adapter...
i stuck a LCD screen protector on the GH1 screen and with a permanent fine line marker drew two horizontal guide lines, i traced footage using lpowell's patch to get the lines in the right place.
1. buy a mobile phone screen guard.
2. cut it to fit your screen & stick the bad boy on.
3. use the custom guideline and put the horizontal to the very bottom of the screen... then press up 28 times... now draw your first permanent marker line.
4. now put it to the top and press down 28 times, draw your second line.
5. turn off the guideline function.
now you can to work within the 2.35:1 lines knowing what will get cropped in post. primitive but works a treat :smile:
