Have the latest firmware update on my 1DC. There are 3 issues I am hoping someone can help with
#1 I assume you must set Sound recording to 'Line input' and NOT manual, but if I set the Rec level, whenever the camera is powered off, either automatically or manually, this Rec level is ALWAYS reset to zero. This seems like a firmware bug to me. This does NOT happen when set to manual. Anyone know of a workaround?
#2 When setting Sound input to Manual, the VU meters are visible, but NOT when set to Line input. Why?
So the solution seems to be, until Canon gets it right, to stick with Manual, and either set the input levels to the first click or use an attenuator.
Can anyone recommend a specific connector -attenuator to use between ZoomH6 and 1DC?
Is this what I need?
http://www.bhphotovideo.com/c/produ...zoomh6_3_5m_line_mic_25db_9.html/prm/alsVwDtl
