Wanted to post this for some time... Currently, the Red One specs are 120fps only in windowed mode. One of the other companies at NAB showed this feature, so I guess it could be added to the Red One, too. It allows 120fps in full frame mode, so it allows full 35mm shallow depth of field combined with slow motion, although at a little bit reduced image quality:
As for as I know, CMOS sensors have every pixel element directly addressable for read out. There is a bandwith limit, so for 120fps, only the inner sensor elements are read out. But as far as I see from other companies, Red could also read out every second or every fourth sensor element.
Every second element:
Every fourth element:
The resulting picture would display something that looks like "enhanced sharpness" (even though it's not) the same way some older cmos cameras had, because there are gaps between the sensor elements. This could be reduced somehow in post. Since there are many cameras on the market that have gaps between elements, I don't expect the picture quality to be too bad, and this mode would be very useful indeed for most of us.
Cheers,
Purple
Code:
|X | |X | |
| |X | |X |
|X | |X | |
| |X | |X |
Code:
|X | |X | |
|X | |X | |
Cheers,
Purple
