digexpressions
I'm thinking about shooting my next event in 24p (been using 720/60p). Since the HMC150 can do 24p in both 1080 and 720, I was wondering if there is any reason not to use the higher 1080p. THANKS
Mad is right about having some leeway with framing, shooting 1080p24, but do realize that if you crop much before downscaling, you will lose some image detail, since the cam can only really resolve about 600 lines...
Here's a question: how does identical footage shot at 1080p compare to stuff shot at 720P then blown up to 1080P? Wouldn't the difference not be huge since the sensor isn't much higher than 720?
I'd be much more inclined to shoot 1080p for delivering SD. That really does give you a heck of a lot of leeway with framing.
I guess that if that is something you find yourself doing often, maybe. Personally I can't remember the last time I cropped a video in that way, I just try to get the framing right to begin with.
1080p does work the encoder a bit harder but I haven't really compared the two side by side to really see by how much. It is a fact however that a higher resolution at the same framerate given the same 21 mbps bitrate will have to work the encoder a bit harder. Now the bitrate is pretty darn good for AVCHD so it could be rare that you would ever notice it but it could be a concern. If you want guaranteed the least amount of compression artifacts I think 720p is still a bit better. Like I said however you may have to try really hard to notice a difference on 99% of video material.
