1080i 24PN Final cut pro settings
Okay, so I filmed a piece with a HVX 200 at 1080i 24PN when I bring the footage into Final Cut Pro via the "Log and Transfer" the browser says the footage is 1280 X 1080 29.97? but says the compressor is DVCPRO HD 1080p30?...
If the camera is in 24p mode why is it recognizing it as 29.97? does Final Cut not pull down frames automatically in this case? Is there a conversion step that I missed?
Thanks anything advice helps!
:undecided
Did you shoot 1080i/24pA, because there are no native modes in 1080?
If you did shoot 24pA, you need to set the preferences in L/T to remove pulldown on transfer.
