A camera or camcorder for making my documentaries?
I suck at flying my drone because I don't do it often enough to know the settings inside and out or to be comfortable flying it around obstacles. But I don't blame the drone or look for some special settings. I know where the problem lies.
I would advise you to go to a good forum that talks about drones to better pilot your drone and then practice a lot if you want to make a good video. ;) I make good shots with my drone.
You are right!!
I certainly don't change lenses often. In a day it can happen to me once or twice. But it was just to make people understand.
So I'll rephrase the answer:
turning on the camera, rotating the VND filter and focusing you need at least 10 seconds. For me that time is sometimes too much. Again, it won't always be like this, but quite often I can't wait 10 seconds.
I'd rather shoot a scene that wasn't perfect than not be able to shoot it at all.
I mean seeing this, I'd probably recommend the FX6. It is a great camera with a built in variable ND. This ND can be set to 'auto' which then automatically adjusts to properly expose the scene. This allows you to just set your preferred aperture with 180 degree shutter speed and not have to worry as the built in ND will automatically adjust to expose your shot. You may have to adjust your exposure compensation as I found that 'auto ND' tended to slightly underexpose (or was it overexpose?.....I forget because I adjusted mine first thing after I bought it) with default settings. The autofocus on it is fantastic as well. And the time from flipping the camera 'on' to actually having an image on the screen is like maybe 2 seconds....very quick. Not to mention you can just leave it on if you get a larger NP battery (no reason to even have the large V-mount as even the NP batteries will last all day.)
Yes, that is great advice if I ever decide to get better at flying my drone I will seek additional training. If that is your specialty, perhaps you can even offer me some expert advice, and then I can ignore it. That's how it works, right?
I answered you in the other thread. What you say about me is all true, but knowing me well and knowing what I do, I liked alaskacameradude's answer. He recommended a camcorder that was faster to use than a camera that is designed for photos. Maybe I wanted to hear this, I don't know. I only know that I have always used camcorders and I have always been happy with them. I also had a shoulder camera with heavy batteries. I remember that I even bought a generator and 25 liters of gasoline to charge them because its batteries were expensive and I had to stay in the forest between Venezuela and Brazil for a long time. And all this alone, just me with the boat pilot. I traveled 1800 km with a motorboat. I was so tired that I couldn't even focus on the scenes, also thanks to the humidity, the steam and the heat of the forest.
I don't think there is any denying camcorder is generally easier to use, faster and more versatile. If you want one you should get one. Due to not much advancement in camcorder and low demand you could pick up one a few years old at a discount or a less fully featured one new. The image quality of all the 1" sensors are virtually the same sensor with different body sizes and features.
I've done live doc work so I understand wanting something as simple as possible so you can spend your energy not on setting up and operating the camera but concentrating on the people and the situation.
Speaking of operating while exhausted, perhaps the increased depth of field from a one-inch sensor would be a good thing. ;-)
Maybe rent one or two camcorders and see what you think? Looks like a four (or so) day rental of a Canon XF605 or Panasonic AG-CX350 will cost less than US$200.
Doug is correct. The GH6 is easy to set up with lots of controls that can be preset. The C1, C2, C3 and C4 dial presets and C4 has more software preset too. So for instance you could set up C1 for early morning, C2 for mid day, C3 for late afternoon etc with appropriate marks on the VND as starting points. Can't remember what lenses you have but the 12-60 or 14-140 cover most things unless you have a wide prime. The GH6 is not good at continuous autofocus but is quick to focus using the AFON button you can use with the thumb when in manual focus. I think you could set up the DJI in similar fashion with ND's for particular time of day etc so that would be very quick to shoot with too.
Could be a case of grass is greener on the other side. Even though GH6 AF isn't great, camcorders are worse, although they have deeper dof. Sometimes you need to try something different and you then can appreciate what you had.
Hi, I'm curious.
I know how important it is to do the White Balance with each profile, but it's not important to do it if you shoot in RAW.
I hope an expert can clarify this doubt of mine:
how important is to do the WB if you shoot in V-Log since the clip you get has a flat profile to be edited in post production?
Thanks for clarifying my ideas.
Ron,
I don't think it's so easy for me to put in place those profiles that you have indicated. Or maybe I'm wrong. I often shoot in villages with huts built on red earth and then immediately move to other terrains with green grass or non-red earth. Sometimes I get horrible results with color casts. My scenarios change continuously.
It doesn't matter if it is red earth or green grass what matter is the white balance for a gray card at that time of day. If you use a light inside a building you can set a custom setting for that too. Of course these may not be perfect but if you shoot Vlog 10bit 4:2:2 you will have lots to play with in editing. You can use PCC in EDIUS to adjust exposure, white balance,tint and saturation.
In that scenario, a gray card could actually hurt one vs a preset if there is a lot of ambient return from the earth or grass that casts on the card and one is moving too quickly or doesn't have a sharp enough eye to notice.
I am not suggesting he uses a gray card in all these situations but to actually set up presets at these times of day rather than use the one daylight preset in the camera.
I don't know how the Gh6 works but I find the Sony presets unusable to me because the WB must be set in the preset. If your presets are 60p, 30p and Log and you want a custom WB for a location. Any time you switch to a preset the WB will revert to the temp when the preset was created.
With the GH6 you can save everything in the custom preset on the dial C1, C2, C3 and C4 that has another set of software preset up to 10 extra. So 13 total. You just set the camera up as you want and save the preset. So frame rate, exposure settings, WB, lens position memory after shutdown, mic volume headphone volume etc. I have mine set up for different theatres I go to that I know the lighting for instance. While in a preset you can still modify any of the settings but if you switch off and on again it will of course revert to the preset selected.
Adriano wants the closest thing to a high quality automatic camcorder. I just felt one solution was to save presets with WB for early morning, mid day, late afternoon and indoors with lighting. One less thing to adjust when shooting quickly. When he is out in the morning it is C1. Use VND to expose using zembras/eyes. Thumb on AFON button for focus. ( I would not trust Auto focus myself but I think he is happy with autofocus ).
That's a creative solution. I think he's not a fan of the complexity. I don't like how preset work because even with that setup if he needs to change headphone volume or turn off stabilization, changing to a new preset resets those settings.
In contrast a camcorder has physical buttons to toggle the WB between auto, a preset or 2 custom WB. At a glance you can understand the camera is settings and know that changing WB won't effect other settings.
Yes, to make preset on the dial C1, C2, C3 is a good idea and good option. But my problem is another. I was really thinking about buying a comcorder to simplify my life. But then I realized that to get the high video quality of a GH6 I would have to buy a heavy camcorder, so I think I will practice more with the GH6 which has a great video image quality, it is small and light. Exactly what I am looking for.
But to get the most out of the GH6 is not easy. In fact I would like to use V-Log fine but I often get the exposure wrong. Unfortunately on the Internet I find few explanations in my language. What worries me most in V-Log is not the grading. Now I have enough experience in grading in V-Log. What worries me is the correct exposure during shooting. What I mainly use to shoot is the waveform. But I have not yet found a good video that explains in detail and exhaustively how to use waveform correctly and to expose well in V-Log. I have tried in many ways to read something or watch videos on YouTube, but the videos take everything for granted and the speaker talk very fast. So, I still have to gain experience in shooting in V-Log on the field and with practice and trial and error..
if you want to shoot Log you need to commit to only shooting Log. You can no longer rely on visually judging exposure by looking at the LCD you need to rely on things like zebras. The camera zebras need to be set different values for example 70 IRE might = 100. If you're struggling with shooting normal there's no point to Log. One moment you want a camcorder and the next moment you want to shoot log.
Someday he's going to realize there is no Easy Button and he's going to actually have to learn some new skills and master his camera if he wants to get the results he wants. Little by little, his questions on various threads reveal how little he knows about the most basic elements of production. But he doesn't want to hear that. He thinks that if he asks enough questions that eventually someone will give him the secret to shooting cinematic video with no effort or knowledge of the craft.
BTW, I want to run a marathon but I don't want to buy any shoes or practice. I just want to run the marathon. Please tell me how I can do it?
I've been shooting V-Log for a few years now, so rest assured that I've done and will do the marathon, even with the wrong shoes. I'm getting results anyway. But since I'm a perfectionist, I want to win the marathon even if it's very difficult.
