I feel like I heard the same arguments when HD was introduced, and then again when 4K started appearing.
It's inevitable that 8K is coming. Really it's already here. Already I see a lot of broadcast 8K cameras are announced for NAB. It's the natural progression of technology. While we barely have 8K monitors, having a higher resolution on capture has some benefits for supersampling, noise. I find many of those high res 8K cameras are actually *softer* on a face because I guess supersampling? If you light for beauty I mean...It's the opposite of what you think on skin.
The benefits are incremental for sure, and good practitioners of the craft will always make great work with whatever they have. I agree though with the notion that it is truly dumb to buy a camera you can't afford media for. That's just bad planning. Having a higher capture just makes that a more expensive proposition in media consumption and speed requirements.
Blackmagic already make a camera that is 12K that can record BRAW to a single CFAST at most of their lower tier data rates. If you use both cards then you get access to all the higher frame rates and it's as simple as putting all the files in the same folder when you offload them. 120@8K at 12 bit log is very very nice for beauty and commercial work. If you forget to put the two cards into a single folder then all that happens is the file plays at half the frame rate you shot. Also easily fixed by merging the two folders.
You can do it with a RED, but it's nice to have a smaller much less expensive camera with non-proprietary media option too. It's really not that different.
