Pro Res will only record to the SSD drive, and the connection for download is MP3 to computer. Unfortunately. Lose the drone, and lose the footage.
You can put up to a 512GB micro SDXC card in the Mavic 3 Cine’s remote too to record a backup copy.
Yeah, you'll get a 1080P signal that's been run through the O3+ compressor for transmission down to the drone. Not sure I'd call that a "backup".
I fail to see how that's comparable to the DJI Mavic 3 Cine. In fact, I cannot believe that people are complaining about a $5,000 drone that's small and compact with the ability to record ProRes HQ to an SSD drive with a 4/3 sensor, 10-bit 4:2:2 color, 5.1K resolution up to 60p, 4K up to 120p . . .
The big issue with Remote ID compliance is, the specs that manufacturers have to comply with by next September haven't even been released yet.
The Autel Evo II Pro only has a 1" sensor and doesn't have the ability to record to a codec as robust as ProRes. I fail to see how that's comparable to the DJI Mavic 3 Cine. In fact, I cannot believe that people are complaining about a $5,000 drone that's small and compact with the ability to record ProRes HQ to an SSD drive with a 4/3 sensor, 10-bit 4:2:2 color, 5.1K resolution up to 60p, 4K up to 120p, that also has a long flight time, 360 degree obstacle avoidance, and an incredible remote with a built-in high-bright screen. One that also comes with three batteries, a three bay battery charger, 6 pairs of props and 8 ND filters. How on earth is this a product we can complain about?
We must be living on different planets.
Sure. Or you could use a drone that records its footage to a removable card and avoid the situation altogether.
My clients are by and large fine with the 10-bit h.265 off of my M2Pro and Autel Evo II Pro. They'd be very happy with ProRes 422... but they'd hit me upside the head if all I had to offer them because of a crash was a "live stream" quality 1080P signal recorded at the remote control.
If the M3 can simultaneously record h.265 to the SD card and ProRes to the SSD, that goes a long way towards alleviating that concern. I'm just not sure it can.
I think I heard someone say that you can record on the controller handset? So that might be a backup option.
The codec from the Autel Evo Pro is plenty robust.
It is 10bit 4.2.2 in H.265 (which is roughly twice
as efficient as H.264.) It also has over 40
minute flight time per battery, claimed 6k resolution
(I’d personally put it closer to 5k) 360 degree obstacle
avoidance and a controller with a built in screen
(although nowhere near as good as the new Mavic’s
screen.) Also shoots 4K 60. Point being it does
a lot of what this new drone does. It’s not as well
specced as this new Mavic but if you haven’t shot
with it, don’t discount it. It has the best camera
I have personally ever seen in a small drone. It
is legit. Enough so that I bought one myself
as opposed to any of the offerings from
DJI.
I've also had no complaints about image quality from any of my drone footage. My EVO stuff just got mixed in with Alexa footage for a high-budget TV spot and they loved it. Is the M3 better? Probably... but we're reaching a point of diminishing returns here very quickly.
