Uwe Lansing
... The GH1's sensor is half the size of the sensor on the 5D...
I`d say the sensor of the 5D is four times larger than that of the GH1:
http://www.wrotniak.net/photo/43/sensor-size.html
bloody germans!
The 5D encodes H.264/mpeg-4 @ up to 47mbps ...
it has four times the area, sure, but sensors are always measured in one dimension. not only is this the norm, it's also the best way to determine field of view as well as dof and other optical properties.I`d say the sensor of the 5D is four times larger than that of the GH1:
... it's also the best way to determine field of view as well as dof and other optical properties.
that's not the point. the point is that the video image isn't as high quality to begin with, for various reasons.At 50mbps you're talking a pretty decent quality 268k per frame @ 1280x720.
If fed the same source data, the GH1's 17Mbps stream would result in higher quality final images than the 5Ds 40Mbps.
That's a pretty big assumption, seeing as there's no way to substantiate that until the GH1 is released. I'll believe it when I see it, and hopefully Panasonic ups that 17Mbps to 24Mbps before the camera is released. 17Mbps just does not make sense when cheaper consumer cams are utilizing 24.
"""cOn the second, it probably beats the Canon. The sensor is 1/4th the size. But it is apparently scanned better than the Canon and higher resolution in the vertical axis. The frequency is high enough above the Nyquist limit that we should be in a good part of its MTF curve. """
Really...
You believe it will better than this.
These are just half rez shots of my friend Barlow's material. The 1080P is even more gorgeous.
http://www.dvxuser.com/V6/showpost.php?p=1565239&postcount=52
http://www.dvxuser.com/V6/showpost.php?p=1561224&postcount=1
Video:
http://vimeo.com/3342835
http://vimeo.com/3604357
Also the G1 is clean, however no where as noise free as the 5D is. That helps big time in the codec chain too.
I hope your prediction is correct that the GH1 will be most likely be superior to the 5d, however if I go with "Akums Razor", most likely not.....
Michael Pappas
http://www.pbase.com/Arrfilms
http://www.Myspace.com/PappasArts
http://www.facebook.com/people/Michael-Pappas/573417404
Arrfilms@hotmail.com
http://www.PappasArts.com
CONTACT VIA AOL INSTANT MESSENGER
AT { PAPPASARTS2 }
barring a firmware update my D90 is heading to the old toy bin.
