Mike Harvey
They're not compatible.
I see. Thanks.Yeah that is one of the only disappointments with the HMC150, it requires an all-new (intelligent) battery. The upside is that you get much more accurate battery life shown on the camera's display
Just bought HMC150. Trying to master lighting. This was a low light test. How'd I do. Also, is there a "best" export setting from FCP. I mainly so event videos, nightclubs, etc...?
http://vimeo.com/6919259
thanks...i'm new here.there's a section to post all videos, under screen grabs / footage hmc150 http://www.dvxuser.com/V6/forumdisplay.php?f=149
Hello, maybe off topic but,Well -- yes and no. I mean, when zoomed in to 35mm, the DOF will be a lot shallower than your camera alone. At 17mm it'll be fairly deep. A wide-angle lens isn't going to give you as shallow DOF as a telephoto lens will. An 85mm or longer lens will give you really shallow DOF.
