yes the Pre production model Panny suffers more than the EX3...there is no doubt. I am certain the production model will perform much better.
Thanks Phillip. Lets hope Panasonic is hearing, and they really do something for the final build.
Does the USB port deliver enough power to run a small USB powered hard drive or does the drive need to have its own power?
I am sure that the build that Philip was working with is not the current version. It is the problem with putting prototypes out there before image quality is finished. There is no serial number on the unit.
Best,
Jan
Yes it does. You do need to go into a menu and turn the USB Host mode on but yes it does. It powered my 360GB Seagate, no problemo.
Best,
Jan
Best,
Jan
Philip, you already held the 1/2" relay lens from Letus for the EX3 in your hands. Are they cooking something for the 300, too? Is your guess that the 300 with a relay lens is as fast as the EX3 with a similar setup?
Correct.So I can use a normal 2,5" drive and offload from cam without a special USB-OTG disk with battery?
No pans or tilts
Beautiful short, tough!
