mcsmooth
Seen a few of your posts regarding CS4. Do you have it working flawlessly? I recently put together a machine intended for native editing. At first it was chewing up 1080p files with ease, but soon found it randomly hanging when skipping around and just couldn't play certain parts of files. So I'm not concerned so much about speed, just that the program is very unstable for me in vista 64 (the import process hangs, maxing out only one core, seems like a common bug). I have to agree that Premiere doesn't use core when it is installed (but it is GREAT for playback on older machines). I figured there may be a way to hack it, but didn't bother knowing that power wasn't an issue and that Adobe is working on the problems.Ok so from what I see so far,
PC's can edit and mac's can't when using Premiere CS4.
I have a 2 gig core 2 duo laptop and 4 gigs of ram with Nvida video card running cuda drivers
(both nvidia video card and cuda drivers are said to accelerate AVCHD).
So I guess that is the baseline system that you need to edit this stuff....
When cineform fully supports CS4, then it will be a no brainer to go that route.
CS3 already edits like DV when using cineform.
(That was how i use to do it, but since the cineform presets are not there, I just edit AVCHD, as I can do that too)
Haven't tried Cineform, but was waiting to hear some more comments Neo and this camera (sounds promising). On the other hand, if Adobe can iron out the AVCHD bugs, I probably wouldn't need it for most editing. But I guess I need to pick a solid codec for projects requiring more work anyway. The joy of early adaption
