FIRST - A report on our changeover in cameras.
We've made our first videos and TV runs with the XH-A1 and HV30 (the HV30 as a B Roll) and the images look absolutely amazing. Having been formerly DVX100B and HVX200 & 200A's we were very (I mean VERY) concerned that the image quality just wouldn't be there and that we'd suffer while trying to convert our operations over to some format of HD that had:
Both the XHA1 and HV30 have conformed to all the above even though the two camera formats are different; that is, ccd's vs cmos; medium vs small (palm) size camera profiles; consumer to semi-prosumer vs pro (though arguably some will argue that the XHA1 is also consumer or prosumer although B&H and our two local broadcasters all labeled the A1 as broadcast pro) camera settings; etc.
In the end of it, the broadcasts approved the show format.
BTW, obviously the HV30 is only good for the B Roll wide shot cuts although we believe it could be used as an A roll - but - we're not going to test for quite a while because this alone was a challenge.
SECOND - The obstacle overcome.
By far our biggest hurdle that we were never able to overcome with the DVX and HVX camera solution in the SD tape mode was that our Avid system would not blend the two videos together in a multicam sync; that is, we always had to digitize the clips and then fuse the clips to a similar format then mulitcam sync which was always a pain when dealing with three cameras at seven shows per month which was what prompted us to look at and add MacPro, MacBook Pro, and FCS2 (other reasons too.)
However, the XHA1 and HV30 cut perfectly together in multicam verifying that the two dv formats are identical and with tweaking from the nearly 50 PRESET downloads we were able to quickly find a PRESET that makes the two cameras look exactly alike despite the two different imagers (which we could get right with the Z7U let alone we had the same Avid multicam issue just like the DVX/HVX one.
THIRD - We have yet to figure out how to get the HV30 out of "stedishot" mode. That is, the HAND is always on and the approval process shots were with that material and the camera mounted on a tripod . . I know, I know, bad! I guess we should have read the manual. Anyone know quickly how to do that? EDIT: This is the "BUT ??"
FORTH - Although we've done numerous tests on the HDV side we have not offered that option to the client yet opting to continue shooting with SD 4:3 until such time as we feel totally 100% comfortable with the HDV to SD conversion off the timeline to DV25 output for the broadcasters. However, we HAVE been shooting a lot of HDV and are amazed at how good the picture looks in low light and have been experiment with a scene we tried to capture last year in Chigrin Falls, OH but could not get the river cliffs to show in overcast (snow clouds) low light without grain and using the VIVIDRGB PRESET with even full ND on we managed to get some stunning footage and are going to post some of it with and without grading to accomplish said look we've been working on and off with for two years and now we have it.
FIFTH and IN CLOSING - Thanks to all who have helped us on the boards in private emails and with phone calls in this difficult task of working through all the possible HD solutions and for your continued help as we dig deeper and deeper into making better images, better compositions, better style, with more creativity.
OBTW, if someone knows hot to quickly get that "steadishot" turned off on the HV30 please let us know. Otherwise we'll have to open the manual out of the plastic wrap.
- Simple media handling solutions
- Archival both short and long term
- Easy for our dual xeon Avid and Mac Pro quad cores to run
- No need for additional media people in the field
- Excellent image in low and medium soft light
- Conforms to our broadcast clients specs
- Had excellent color out of the camera
- Had a media format that had plenty of color bandwidth for color grading where and if necessary
