Dino
They are not *yet* uncompressed. Uncompressed support has been stated for the XDR, but not the Nano, hence my comment about having to step up with a few more grand. And yes, I am aware the F900R is HDCam, thanks. However, it also offers two SDI ports so it can also output uncompressed 4:2:2 or 4:4:4.
PerroneFord, your previous post referenced things that are ready right now.
The above solutions are not uncompressed. The F900R has two HD SDI outputs, but this is not intended for Dual Link HD SDI to enable 4:4:4 recording
externally, just for using multiple monitors--my HDX900 has two HD SDI outputs
also, but not Dual Link. Speaking of colorspace, did you know that HDCAM only
provides 480 pixels of chroma per line?
Any camera equipped with an HD SDI output can theoretically output a 4:2:2 uncompressed output, including an HPX170.
I did not say it would offer a 35mm field of view. Pretty tough to do with a 1/2" imager. However, a nice set of digiprimes will close most of that gap nicely. If one wanted to get all the way to a 35mm FOV, then yes, an adapter would be required.
Not sure why you're trying to slam me for things I neither said nor implied.
I'm not sure how Digiprimes will close the depth of field gap using a 1/2" to 2/3" lens adapter, but the magnification won't be as extreme as with a Nikon or PL
mount adapter--however, less magnification means deeper depth of field.
I am not trying to slam you in any way, just trying to be accurate. I totally agree that an external recorder can yield better results than the XDCAM EX codec built-in to an EX1.
