michellefinch
http://www.dvxuser.com/V6/showthread.php?t=142742
This pulsating periodic artifact seems to be similar to the post above. It was suggested that it is an mpeg thing related to gop compression.
michellefinch, what compression do you use?
I looked at the clip and I think the effect is different. In that link the pixels are shifting around in a different way than my problem... that problem definitely looks like a compression or encoding issue.
My problem- the "breathing background"- can't be because of compression, because it happens in the Final Cut monitor before even compressing it or creating a file or DVD from the footage.
We capture all of our footage from a deck into FCP with all of the standard settings.
Could it be a capturing issue or a setting? I haven't checked the original tape in a larger monitor yet to rule out a camera problem. But I did rule out the "steady shot" setting theory- I never have that setting on when on a tripod (or handheld, for that matter).
