Ok guys here's some footage, quick test...
http://homepage.mac.com/segarza/hpx170/imageshift.mov
First rack focus. Then I gently tapped the int microphone, as a reference to see how much of the movement during the rack focus is due to camera shake and how much accounts for the image shifting. Then I gently tapped the focus ring. You be the judge!
It's a non-issue with my camera, but might be an issue with yours.
Wait, you do have a 170, right?
Am I missing something here? I'm light on experience, but this looks like footage shot from a camera on a very light tripod, or no tripod at all.
Also, we are talking about using the manual focus ring, so this shouldn't be an issue using a remote. Is that correct? Can someone verify this?
I questioned that too. Because my HPX170 does not have these issues that some others are showing and describing. This lens is designed to move in the event it gets bumped. The shock mount is for protection. This image wobble may be happening because of a faulty shock mount - I'm just guessing. Otherwise we would all have the same exact problem.
No flaw? Design flaw? Manufacturing Flaw? Let's sort this out. Waiting on Jan to report back what the Osaka people say.
The HPX170 was mounted on a Sachtler SADV8SB2S DV-8SB/2D Aluminum Tripod System (Supports up to 26.5lbs)
The HPX170, according to specs, weighs 5lbs with battery...
