aurantaurant
DINO,
Forgive me, English is my 5th language...
Because you're not used to using these types of cameras with an adapter, there is going to be a learning curve for you to figure everything out. The problem you're describing...
Is due to the OIS being enabled on the camera. If you're using an adapter or you are zoomed all the way in without the adapter, you're going to get the side-to-side jump. I dealt with this myself when I first started using my adapter.
I watched your video and went "Oh F me... now im not buying that crap" Then i tested my HVX and it does the same thing.
Turn off the OIS and it will be fine. My HVX200 has the same side-to-side play on the lens and I've won two oscars with my Redrock and HVX (just kidding) Not kidding about the side-to-side play though. It's the same as your Vimeo video. I've never had a problem.
Another alternative would be to sell me your defective HPX170 for around $3000 seeing as Panasonic's warranty won't cover this issue... making your 170 essentially worthless. Feel free to PM me if you want to sell it. MOOOOOOhahahahahaha!!!!
-Chowder.
... The image shifts from side to side while focusing...
-Chowder.
