Yesterday I tested the digital zoom feature on the HMC150 as I routinely take a lot of long shots and can use the longest lens possible. Also, I wanted to see if this could make up for the 13X versus the 20X lens on my Canon XH-A1.
I captured a few different scenes at 13X and then switched on the digital zoom at 2X, 5X and 10X. I reviewed the footage at home directly on a 51" HDTV and by rendering a 720X480 DVD to view on a 25" SD monitor and DVD player.
Good news first.
Using the 2X digital zoom introduces very little visible noise on the 51" HDTV monitor. Probably no one would ever see it. There was no noise or effects visible on the 25" monitor. It looked great. I would consider the 2X digital zoom usable any time. Still, you should test it before depending on it. Some backgrounds other than my test shots may be better or worse.
Then the (expected) bad news.
Using the 5X digital zoom introduces a lot of visible grain and noise. Im not sure what you would use this for on a HD camera except some extraordinary event you just had to get closer too. It does really extend the reach, but even on the 25" monitor, it looked bad.
Like you might have guessed, using the 10X digital zoom was horrible. It went way beyond visible noise and grain to actually seeing blocks visible. Why this would be put on this level of camera is beyond me. Totally unusable for anything.
Good news first.
