Barry_Green
Moderator
Sure, I can see that; I wouldn't render down to AVC-HD though for intermediate renders, so that's why I didn't catch what you meant there.
A book is underway, but so far no territory has chosen to include it with the camera so it'll be available separately.Oh okay. So are you going to write an HMC150 book for inclusion with the shipping units?
No standard-def on the HMC150 at all. You'd have to do any standard-def conversion in post. It can, however, output downconverted standard-def over its HDMI, component, and composite video outputs, so you could capture standard-def from its high-def playback if you had an HDMI, component, or composite capture card.1. Any standard-def recording modes? And, if so, any estimate of how much video will go on a card?
Didn't test that side-by-side, but I think they'll end up about the same. You're talking about 51mm on the HMC150 at maximum zoom, vs. 45mm on a DVX100. But the HMC150 has a slightly larger chip, so a slightly wider field of view. So my guess is that the telephoto will be about the same, but the wide angle will be enormously better on the HMC150 (due to several factors, including it being 3.9mm vs. 4.5mm, it being 16:9 vs. 4:3, and it having a larger chip vs. a smaller chip).2. Any idea how the maximum zoom on this will compare to the max zoom on the DVX100? The fact that it's 13X vs. 10X obviously suggests that it will zoom in tighter, but I ask because I've seen it said that the HMC150 starts out wider, so I'm wondering if that cancels out the advantage.
A book is underway
. . . Say from a HVX200, how much space would 1 hour of HD footage take up. Thanks again for all your insight.. Rockin... b.p.
For 1.5 hours:
ProRes 422 1920x1080 = 93gb
ProRes 422 1280x720 = 47gb
I believe that is what Log and Transfer uses to transcode HMC150 footage
The 176 gb for 20gb figure sounds like ProRes 422 HQ 1920x1080 which is arguably overkill for this camera
I think so, but a) I haven't tried it, and b) I'm not 100% sure the Intensity even supports SD, but assuming it does, then yes that should work.So you are saying that if I got an inensity for my Mac, I could capture SD right into say FCP (even though your not a FCP guy).
Yeah, I'm not feelin' the whole "grow your files by 10x" workflow. I'd rather cut native if possible. It depends on your computer and the implementation of how it handles the AVC-HD and how it spreads it across multiple cores, but I've seen surprising performance on modern hardware, even from the native footage.I am working on a wedding that someone else shot in AVCHD. It was like 2GB of footage in it's native format then after I converted it to PROREZ it was 25GB. That's insane.
About 22 GB of 720/24pN, or 55GB of 1080.Say from a HVX200, how much space would 1 hour of HD footage take up.
No, there are many other cameras that record high-def footage direct to SD cards.so barry, is this the cheapest hd camera out there now.. as far as sd card and capture fcp (whatever software you are using) without a hd capture card
the HMC70 is sold as a professional model but it's basically an HSC1U shoved into a shoulder-mount body, no manual focus ring etc.)
HMC150 + native AVCHD editing = Priceless.
