Neal Buconjic
how many days do you have it for in this 4 hour set up? also the breakers, how many amps are they, and was the upgrade just a breaker box or higher amp wire?
a little time, a couple weeks before you go into shoot, go in during there closed time, and start testing out the brakers, easy way is to take a small 110 light, have someone plug it in while you start flipping, once it shuts off the light, write down which breaker handles that outlet also take note of what else in on that breaker, house lights, coffee maker, anything, then once you map out the outlets and breakers, include that in your lighting diagram.
I've got it for as many weekdays as I need. I'm hoping to pull it off in two, but fully expect to run into three (or more) if required.
Funny you should mention the wiring diagram. I inquired whether they mind if I determined which circuit was on each breaker so I could label appropriately and make a diagram. They didn't mind, but didn't want me doing it then and there. Maybe on a morning next week. They kept saying "Don't worry about it, we have bands plugging their equipment into the outlets all the time". Better safe than sorry.
The breakers are 20A, but I didn't inquire whether the wiring was upgraded.
