Barry:
Do you have a drop dead ship date yet for either new cam?
Nope. All I've been told is "September" for the 170, and "fall" for the 150.
It's september folks when will the hmc-150 come out , can' t wait !
Can anyone confirm if the european version will be switchable ?
Barry, how similar is the position on the thread underneath in relation to the front of the lens compared to the dvx, i have a 35mm adaptor and some other bits that i made to fit the dvx, will current dvx mattebox/bars combos fit right onto the 150?
I did get an official launch date from Panasonic's HMC150 product brand manager. He said "October 2nd."Sounds like the Panasonic rep may have been "optimistic" with the date of Sept. 4th
Hmmm...
Don't know everything for sure, but I put the Ultimate on the HMC150 and it looked pretty darn good as is. My Ultimate has the HVX achromat. You can see some stills earlier in this thread (the shots of the prairie girls).I'm sure this has already been asked somewhere else in the 49 pages of this thread but does anyone know if the Letus35 Extreme (or Ultimate for that matter) HVX200 Optimization Package will work with the HMC150?
Can't answer anymore as I had to send the camera back. Sorry.Barry, how similar is the position on the thread underneath in relation to the front of the lens compared to the dvx, i have a 35mm adaptor and some other bits that i made to fit the dvx, will current dvx mattebox/bars combos fit right onto the 150?
I guess that depends on your capture board and whether it has a TC IN jack, but the HMC150 outputs standard LTC timecode out its composite video jack if you put it into timecode sync mode. So if you had a capture board with HDMI input and LTC timecode input, yeah, that might work.I'm pretty sure that you don't get metadata and time code when capturing through the HDMI connection. Is there a way to capture with TC?
Anybody?
-Russ
Hey Barry,
How much do you think can be gained by capturing from the HDMI port instead of the SD cards?
For say, keying work?
Substantial image quality gains?
I assume you had an original DVX100? The 100A improved on this, and the 100B was better still, and the 200 was better. I'd still like a little more damping in the zoom even so, but it's way better than it was back in the original DVX100 days. The focus ring is buttery smooth with a huge slow graceful travel of about 300 degrees.I wonder if the zoom and focus ring have any "viscous" resistance (don’t know what its called). I am always jealous of how buttery smooth Sony focus rings are. My DVX100 and DVC80 always had very sloppy focus and zoom rings that looked terrible when used manually. You could never ramp up or down without it looking jerky.
Nope. Doesn't have that.Also, the Sony has another feature I would love to see in the HMC, programmable rack focusing. In the V1U, you can set a beginning point of focus and an end point, and hit execute and it would perform the rack automatically (and will do the same for zooms).
