Mine is a 1.8ghz core2duo with 2gb of ram. Not the best setup but since HDV runs fine on it I expected these files to run fine as well. What preset did you use in Premiere?I dropped it into photoshop CS3 and premiere CS3 and it runs fine. I have 3ghz core duo and 2gigs of ram. Dunno what your setup is. I used their preset.
lol those D90's are going to get raped. PPL will use it for timelapse, standard stills and movies.. i wonder what the average life expectancy will be :>
If you are taking lots of movies that kind of nothing... right?Shutter in the D90 has been tested to 100,000 cycles.
I tried the 720p 24p HDV preset and there was sadly no difference. It's pretty sluggish when I scrub through it and when I preview it. However, scrubbing through it works a whole lot better when I use the desktop setting instead of HDV. I'd say it scrubs perfectly, but still the preview is very sluggish. It doesn't render for preview, and I don't think it should have to. Grrr... Nonetheless, thanks for your help. I appreciate it.I'm at work right now, but I'm pretty sure it was the HDV preset when you first open it? I wish I were at home to tell you, but I'm pretty sure it was that. What's it doing exactly? When you scrub is it sluggish? Render time to preview?
Does each frame of a movie = 1 cycle?
LOL that can't be right, because 70min of 24fps= around 100,000 frames. lol
The cycles have to do with how many times the mechanical shutter flips open and closed. As far as shooting video, this won't be happening at all.
Flash cards for video, flash cards for audio. No 35mm adapter. Light weight. Portable. Firmware upgrades. Car mounts!!! Smaller Tripods. Modest needs? This is what I need.
This looks like good news in the menus: Could this mean that when you press the AE-L button it stays locked?
Menu:
Assign AE-L/AF-L button • AE/AF lock ¹
• AE lock only
• AF lock only
• AE lock (hold)
• AF-ON
• FV Lock
